07-03-2005 07:34 AM
07-06-2005 07:47 AM
The best way to do this would be in either a functional global (also called shift register or LV2 global) or a single element queue. You can also use either of the two GOOP toolkits. I would recommend the queue approach, as its performance is much better than the others. You can find code examples and more information on this thread - Clusters as data structures.
I have also attached a presentation I gave at NI-Week a year or so ago explaining the design of large LabVIEW programs using the shift register approach. It should give you a few hints (and laughs). Let me know if the LabVIEW version is wrong for you and I can down convert as necessary.
