Passing a pointer parameter for DLL
Hi Guys:
I am little lost on how to execute below for my call library function node, please give me your best shot and thank you in advance:
GetHardwareInfo
This function takes a pointer to an array of bytes which will be loaded with three values:
1. I2C frequency (note that the value returned is the I2C frequency divided by 2)
2. 3.3V Power Output State (0 = ‘On’ and 1=’Off’)
3. 5V Power Output State (0 = ‘On’ and 1=’Off’)
C/C++:
int
GetHardwareInfo(uchar *HardwareData);
Joey
Message 1 of 18
(5,433 Views)
GetValueByPointer.xnode
C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\Utility\importsl\GetValueByPointer
- James
Using LV 2012 on Windows 7 64 bit
Message 2 of 18
(5,424 Views)
@ZhuoCao wrote:
GetHardwareInfo
An array of bytes is an array of 8-bit values (U8 or I8). Configure the Call Library node for that parameter as an array of U8, passed by Array Data Pointer.
Message 3 of 18
(5,418 Views)
Hello:
How do I pass the (uchar *Hardwaredata) into the DLL?  It is suppose to be a pointer value, I am not sure how to set it up.  What value do I connect to it in the block diagram, is it a string input?
Message 4 of 18
(5,402 Views)
For more, go : Help - Find examples, then Search, type DLL and open Call DLL example !
Message 5 of 18
(5,391 Views)
No need to typecast to a string, just pass the array directly:
Message 6 of 18
(5,379 Views)
Or some other of those many methods left 🙂
Message 7 of 18
(5,373 Views)
Thanks for all the support guys, unfortunately I tried both methodologies and still having error 1097 for passing the string pointer and the u8 array pointer. See below, am I missing anything else?  I made two queries to the DLL and able to get the correct values back so I know I am connected to the DLL.
Message 8 of 18
(5,365 Views)
Do you have the function code, especially the part where it operates the input *uchar ?
Message 9 of 18
(5,361 Views)
No I don't, I will contact vendor below and see if I get more details on the function call.
http://www.i2ctools.com/products.html
Message 10 of 18
(5,359 Views)
