Passing a parameter (java) through invoke node
HI.
I have separatde the code example below into sections, please read my coments.
I have opend the code as activeX, and I can access all the methodes, but passing the selected adapter is a problem.
This part works, I can get the default adapter and read it out to my .vi front.
boolean doing_work=true;
// get the default adapter from the service provider
DSPortAdapter adapter = OneWireAccessProvider.getDefaultAdapter();
This part does not work, I get an error saying that a parameter is missing, my guess is that the missing parameter is the "adapter" (as in adapter.beginExclusive()
// work loop
while (doing_work)
// get exclusive use of adapter (SESSION)
adapter.beginExclusive(true);
// clear any previous search restrictions (NETWORK)
adapter.setSearchAllDevices();
adapter.targetAllFamilies();
adapter.setSpeed(adapter.SPEED_REGULAR);
// enumerate through all the 1-Wire devices found (NETWORK)
for (Enumeration owd_enum = adapter.getAllDeviceContainers();
owd_enum.hasMoreElements(); )
// get a ‘container’ for each device
OneWireContainer owd = ( OneWireContainer ) owd_enum.nextElement();
// do SOMETHING with device found (TRANSPORT/FILE/DEVICE)
// end exclusive use of adapter (SESSION)
adapter.endExclusive();
// do other application work
It has to be said that the original code is Java. But since parts of the code works, and all I need apparantly is to find out how to pass a parameter.
The project is 1-wire (micro-lan/ibutton) and additional information can be found on www.ibutton.com. Also I'll provide all the information that I have. The 1-wire usb adapter can be ordered as a sample from the above site.
Please help!
(2,803 Views)
I have now been abel to get some parts of it working.
I can even read the uniq ID of the thermometer, but I have no success in reading the temperature.
If you have any experience with 1-wire, please contact me
J;-)
(2,777 Views)
