Passing a class pointer to Call library function
I am calling a c++ dll from call library function. I want to pass a class pointer to call library function .
How can I perform this! Can anyone guide me regarding this option.
Thanks & regards,
Maithili
(3,346 Views)
I don't think that's possible.
Doug De Clue
Maithili wrote in message news:<50650000000800000015560000-1027480788000@exchange.ni.com>...
> Hello,
> Thanks & regards,
> Maithili
(3,346 Views)
I'm not sure whether you are passing a pointer to an instance or a
pointer to a class, but if the DLL has another function that returns the
pointer, then you can do this. Call the other DLL function, treat the
pointer as a U32, and pass it into the other functions that need it. In
this way, it is no different that any other refnum, HWND, HDC, or any
other private type.
If the DLL doesn't have a function to return this and you are wanting LV
to access globals/exported data within the DLL, then you are out of luck
at this time. LV only deals with exported functions.
G
reg McKaskle
(3,346 Views)
