Passing a LabView struct to a C++ DLL
Hello everyone,
I am new to working with LabView, and have the following question:
suppose I have a struct declared in LabView, is it possible to pass this to
a DLL created in MS Visual C++ 6.0 ??
If so, do I have to declare the same struct in the DLL to use it, or how
would one go about to implement this...???
Any suggestions welcome,
Gunter
(3,194 Views)
Try this link.. there should be an example here that will help.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000006E600000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Regards
Ray Farmer
Regards
Ray Farmer
(3,194 Views)
GV,
Is the DLL created yet? If it is, then find out if the DLL is packed at 8 bytes (the default) or one byte (what LabVIEW does when passing structures). If the DLL is packed at 8 bytes, then you can add dummy numeric values to your cluster in LabVIEW to fill up the space.
If the DLL is not created yet, then see the following:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/7d6a20fe02edbf318625690700704cf3?OpenDocument
http://zone.ni.com/devzone/explprog.nsf/webmain/9E21592A5F39238C862569880064D694?OpenDocument
http://pong.ni.com/public.nsf/websearch/A6705FEC7EA42300862567B70054206E?OpenDocument
Randy Hoskin
http://www.ni.com/ask
(3,194 Views)
