Passing MATLAB 'cell' data types between MATLAB script nodes in LabView?
Hi all,
I need to pass a cell data type variable from one MATLAB script node in LabView to another, but cell is not listed as an "output" data type in the script node.
Is there any way to do this without converting to a 2D array?  Each column in my cell has a different number of rows...
Thanks!
Mike
(3,251 Views)
Accepted by topic author mk@opc
Nevermind...
Instead of using a typical LabView wire I just said
assignin('base', 'varname', varvalue);
in the first script and called varname from the second node to get my cell.
Easy... duh 😛  Leaving here if anyone in the future has the same question.
(3,231 Views)
