Passing Data from a sub
I have a simple sub that just has a For loop with the usual index. I want to pass the index to the main vi program and first tried pasing through a wire and connector output to the sub. However, the index does not pass since the loop is busy in the sub. I can use a Global variable but the index just goes to the global variable front panel. How do I get the index numerical value to the front panel of the main vi?
Message 1 of 11
(4,032 Views)
Do you want pass all the values as from 0 to 500 in array or you what to pass one by one.
Message 2 of 11
(4,026 Views)
Did you try using a functional global? Chek out the attached example.
NitzZ
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved;))
Message 3 of 11
(4,016 Views)
Accepted by topic author tomnz
Create a reference to your Index in your main.vi and pass this to the SubVI. In your SubVI write your index value to the Property Value.
Dont forget to include the reference on you connector pane
Regards
Ray Farmer
Message 4 of 11
(4,009 Views)
You can also try this approach using the control refernce. Though i would suggest the Functional globals.
Nitzz
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
Message 5 of 11
(4,006 Views)
example
Regards
Ray Farmer
Message 6 of 11
(3,992 Views)
Thanks but I am a bit confused as to what to put in the main prog. I have this (attached) but it doesn't work.
Message 7 of 11
(3,975 Views)
Ok I got it now. Great solution - simple.
Message 8 of 11
(3,969 Views)
Fascinating but too complex
Message 9 of 11
(3,959 Views)
only problem is when you press the stop button, you have to wait until the 500 iteration of the For loop has complete which is why I changed the subvi to a while loop so that the button is passed down too the subvi to stop the while loop as well.
Regards
Ray Farmer
Message 10 of 11
(3,944 Views)
