Parsing the bit pattern.
If I have a 32 bits number. How can I parse out a
particular bit pattern? For example, I need to
parse out this 32 bits to two 16 bits patterns, or
any bit pattern.
Thank you.
(2,859 Views)
Check out the "Number to Boolean Array" function on the Boolean palette. I think this does exactly what you are after, and it's got a partner "Boolean Array to Number" function to go from a bit pattern back to a numeric.
Hope it helps,
John Lum
(2,859 Views)
Thank you John.
I will give this a try.
Van
(2,859 Views)
