Parsing text files
I have written a vi that parses data out of text files which makes use of the open text file vi. When I compile the vi to run as a stand alone application, The open file dialogue will only accept .vi files for opening. Why is this?
Russ T.
(2,705 Views)
Without looking into your program, I am going to guess the following:
If you are using Open/Create/Replace File.vi, wire in "*.txt" to Pattern.
Hope that helps.
Shan Pin Koh
Systems Engineer
Oakriver Technology
(2,705 Views)
