Parse string into array for comparison
Hi All,
I am trying to parse a string message into an array of numbers so I can check if my event was successful.
\FF\FE\01\FD\02\00\00\00
I know I just need to read through and discard the \, but I don't know how to do that in Labview. I just need to check if the 6th byte = 00 or not.
Thanks! I mostly need help with parsing in labview.
Message 1 of 9
(5,499 Views)
right click on the string and click the slash code.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(5,490 Views)
I would use the spreadsheet string to array vi with "\" as the delimeter and convert to unsigned bytes.  See example.
Message 3 of 9
(5,486 Views)
Assuming this is a plain ASCII string containing the letters 0..F and "\" as delimiter, you can simply used "Spreadsheet string to array" with the following settings:
Type= 1D U8 array
format= %x
delimiter= "\"
One problem is the extra delimiter at the beginning, so use array subset to skip the first element.
(EDIT: Ahh, Darin beat me with a similar solution. Mine's a little easier ;)).
Message Edited by altenbach on 08-06-2009 04:30 PM
Message 4 of 9
(5,484 Views)
altenbach wrote:
(EDIT: Ahh, Darin beat me with a similar solution. Mine's a little easier).
I was expecting you to have some byte-swapping, type-casting, hex-code-displaying, quick-dropping action that would somehow manage to do it in a single step.
Message Edited by Darin.K on 08-06-2009 07:40 PM
Message 5 of 9
(5,456 Views)
Well, technically, the original question was
amita wrote: I just need to check if the 6th byte = 00 or not.
Thus, you could simply just do this:
 Smiley Wink
Message Edited by smercurio_fc on 08-07-2009 10:11 AM
Message 6 of 9
(5,412 Views)
Well, I did not read that far.... 😮
Message 7 of 9
(5,404 Views)
Here's yet another variation... 😉
Message Edited by altenbach on 08-07-2009 04:59 PM
Message 8 of 9
(5,380 Views)
Parsing the question is almost as much fun as answering it.Smiley Happy    I originally considered this solution as a more general demonstration of parsing strings in LV.  When I have a (complex) string to parse I often use 'Scan String for Tokens'  as shown in this example.  Not much harder than the other solutions and no need to deal with the issue of the leading '\'.  I think we still need a Rube Golderg solution as well as an obfuscated version.
Message 9 of 9
(5,370 Views)
