Parse String Help
I have data that is in the following format: 00.12\s\sT\s13.86\r\nS\s03.78\s\sD\s142.3\s\sW\s01.26\s\sT\s13.97\r\nS\s03.97\s\sD\s148.4\s\sW\s01.1
All that I need from this string is the data between the first "\r\n" and the second "\r\n", and ideas on the easiest way to pull that data out?
Cheers!
(6,718 Views)
This should do it.
Message Edited by Stradis on 10-12-2007 08:38 PM
Paul
(6,712 Views)
Or, you could place two match pattern functions. Wire the "after substring" from the first as the input to the second. "\r\n would of course be the regular expression for both.
(6,696 Views)
