Parse Mac Address with match regular expression
Hi Everyone,
I have a problem with the Match Regular Expression function,
I am trying to parse the response two a arp -a 192.168.0.15 request in order to extract MAC address of this remote IP, I used the following RegEx: ^([0-9a-fA-F]{2}[:-]){5}([0-9a-fA-F]{2})$
I am wondering why do I need to do a string subset first to extract only the MAC Address part. Isn't Match Regular Expression function capable of recognizing the RegEx directly in the middle of a string?
I only works when I extract the right tring subset as in the picture bellow.
Thanks for your answers.
(4,922 Views)
Accepted by topic author Olivioloyer
Get rid of the "^" in the beginning of your regular expression. You are instructing it to find the pattern at the beginning of the string.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,918 Views)
Hi Mark,
Thanks a lot for your answer, I did what you said, and I still see no change.
the answer from arp -a is :
Interfaz: 192.168.0.16 --- 0xb
  Direcci¢n de Internet          Direcci¢n f¡sica      Tipo
  192.168.0.15          00-04-7e-02-21-10     din mico
and the whole match output gives nothing ""
OK found the answer I also must quit the $ at the end,
Thanks a lot Mark,
Have a great day
(4,913 Views)
Sorry, I should have noticed the "$" as well. Glad it is working for you.
Mark Yedinak
LabVIEW Champion
(4,907 Views)
