Parametric Analysis models AR, ARMA, MA
I would like to ask if I am able to use methods of parametric modelling with Labview.
For example, I used with Matlab and Agilent VEE, methods of parametric modeling like Burg or Yule-Walker estimation.
Are there any VI's in Labview that allow the user to work with Burg or Yule Walker spectral estimation?
Thank you, have a nice day.
(3,309 Views)
You can use the MathScript Node in LabVIEW as long as you have more than the LabVIEW Base package.
Also, there is a System Identification Toolkit for LabVIEW that is made specifically for this type of stuff.
Hope this helps!!
Dan
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(3,298 Views)
