Parameters list
For my new software, I need to store parameters.  I would like to be able to update them in my software.   I have a lots of parameters, so I would like to group them and display them by group ( the right part would change when you select another Parameter group).  I saw this in C# and I was wondering what was the best way to do in in labview.  My parameters a usually stored in ini or XML files.  I thought of using a Tab but I cannot save it as a control.
thanks for your help.
(3,258 Views)
You could certainly have all your controls in that one area, and set the visibility of the controls with a True or False depending on what group you want to show.
I would use a tab control myself.  You and hide the page selectors if you want to.  I don't understant what you mean by your comment that you can't save a "tab as a control".
(3,244 Views)
Make the right side a tab-control and have it change tab when you select something from the left side. Easy. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,238 Views)
I just understand what I was doing wrong.  I was trying to put a tab in a cluster.  That's why it wasn't working.
If I use ini files,  I can update only a section of it right?
(3,227 Views)
