Parameter Values for ST-133 controller when using serial communication with LabVIEW
What would be the parameter values (Baud Rate, Stop bit , Parity bit etc.) when using serial port communication to communicate with a Princeton Instruments ST-133 controller which controls a CCD camera to produce an outpue voltage of 5 volts. What should be the serial Write input if I have to acheive this. Would using a square waveform generator work.
(2,430 Views)
Why do youo keep starting new threads? You have posted similar questions here and here. There are LabVIEW drivers mentioned and the manual you linked has no information on the serial connection. You need to get that from Princeton Instruments.
Communicating to a serial port with a square wave generator is silly.
(2,428 Views)
Ssorry about that. I will take care in the future.
(2,423 Views)
