Parallel port limitation
Does anyone know whats the limit of the parallel port (current source and
sink characteristics)
(3,092 Views)
You can find this information in a number of resources. Try "Upgrading and Repairing PCs" and other such hardware reference materials. This forum is probably not going to be your best source of information for those specifications.
(3,092 Views)
Hallo, pcf,
Du (pcfnet) meintest am 18.07.02:
> source and sink characteristics)
That depends.
There is no strict design order - every chip designer can make its own
design.
If you use a port on a laptop or a port which ist powered directly by an
on board chip: be careful. Replacing a burned chip may be hard work.
Greetings!
Helmut
Please excuse my gerlish!
(3,092 Views)
pcf:
Current limits are pretty low for parallel ports, I believe on the
order of <100mA but I'm not absolutely sure so be sure to check out
the website I'm going to mention in a minute. Remember these parallel
port chips are basically just regular 5V TTL. Laptops are even lower
because of lower operating voltages (3.3) and CMOS implementations.
You may need to build a driver circuit with some opto-isolation
protection for your PC if you are trying to drive more current than
100ma per line.
The best place to check for parallel port information is Lakeview
Research's ww.lvr.com/parport.htm Jan Axelson's "Parallel Port
Complete" is the best text on the subject and reasonably cheap (about
$25) and the website is her website with a lot of links for parallel
port information.
Lakeview Research's website also has information on serial (RS-232)
and USB interfacing as well. www.lvr.com
Douglas De Clue
LabVIEW developer
ddeclue@bellsouth.net
"pcf" wrote in message news:...
> Thanks,
(3,092 Views)
