Thank you for your replay,
I've used the VISA Open vi to open the ASRL10::INSTR device (LPT1) as was suggested by
Kevin B. Kent in the previous replay, then I used the VISA Move In8 setting the offset
number first to 1 then to 2 (as you suggested) but I got the following error back:
Error -1073807346 occurred at VISA In 8
Possible reasions:
VISA: The given session or object reference is invalid.
How else would i be able to refrence the registers, or am I using the wrong vi's??
Jim Kring wrote:
> The base address of LPT1 is usually hex 378. This is the D register. The
> Status register is at the base address + 1 (hex 379). The Control register
> is at the base address + 2 (hex 37A).
> -Jim
> Murad Karrar wrote:
> >Hello,>>
Does anyone know how to access the parallel port control and status>registers,
> The serial port write vi doesn't support this. I've looked>every where in
> the documents for it but to no avail.>
