Parallel Port Detect TTL Voltages
I'm trying to use LPT1, my printer port to detect incoming voltages. The voltages are 5V and 0V, high and low. I know that parallel ports are capable of detecting the voltage changes.
As I'm new to Labview programming, can anyone be kind enough to guide me along?
From
Don
(2,846 Views)
Look in the Labview directory examples\portaccess\parallel port examples.llb for examples on how to use the parallel port.
- tbob
Inventor of the WORM Global
(2,833 Views)
As tbob says...
If you have LV7, there may be more examples by doing a seach using the example finder for the parallel port. There were a few last time I checked. There are a couple of very useful ones which allow to write/read any lines of the port.
Read the instructions as well, because you may need to set your port within the BIOS (CPP / EPP / Standard) modes.
JLV
(2,825 Views)
