Parallel Port 16bits data half-duplex
Can I configure the PC's parallel port for a 16bits halfduplex comunication?Where can I find a .VI doing that ?
(3,049 Views)
There is no VI that would allow you to do this.
Actually, the parallel port cannot have 16 lines for input or output. I believe there are 8 output lines and 5 input lines.
Zvezdana S.
(3,049 Views)
Hi Zvezdana & Catalinp,
in general you are right, the Printerport allows only 8Bit transfer (bidirectional is possible) - but you should not give up too fast. With a little help of simple circuitry like
74HC4094 (4 of them are needed) you can solve this problem. Have a look to Datasheet of 4094 and you will see, how to clock Data into this Chip and how to connect a second Chip in series.
If only the parallel port is available you should "serialize" the 16bits and shift them out into two of these 8-stage-shift-and-store-registers - like a typical SPI-Interface. The same has to be done for Input operation. The speed of this Interface will be not very fast because of this overhead of clocking-out and �in ; but it will work.
Hope this leads to some
new ideas about this issue.
Regards
Werner
(3,049 Views)
Thank you Werner!
So there is an answer...I don't understand very much of your comment...but I'll try to read more on the subject. I think my problem is more simple (than your comment), I need to write to parallel port on more than 8 bits...and my ideea was to use the input bits-for output too. It's possible...is an answer&thanks again !
(3,049 Views)
there are of course other possibilities if you need to output 16Bits. Find attached a piece of schematic - there are two 8bit Latches used. The io-board.vi uses the control-port-Pins of Printerport for clocking Data into these Latches or to make them transparent. In case you select out0x, the circuit D2 in schematic is meant, out1x ==> circuit D3. The 5 bits of schematic in input direction are used with InPort.vi. (third address of LPT-sub.vi).
still questions ???????????
Werner
(3,049 Views)
