Parallel Access DVR Bug - LV2017
Admittedly I'm tired so I could be missing something VERY obvious. If so, hope someone could at least confirm they are seeing the same behavior and explain it. I'm in disbelief that this is a bug because there's nothing subtle about it. Someone just needs to explain to me why this is normal and expected behavior and then I'll promise to get a good night's rest and start tomorrow a fresh day.
I'm using LV2017 f2 32-bit on Windows 10 64 bit.
(4,523 Views)
I'm using LV 2014 so I can't configure for read only access, but it looks to be a bug.
(4,498 Views)
Confirmed on my 2017, it seems the "Read only" still writes and thus empties the data.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,427 Views)
After confirming this in my LabVIEW 2017 as well, I did some searching and found that R&D is aware of this issue. Unfortunately there's not a listed workaround right now. The CAR number is 663379, so keep an eye out for future patches/releases for a potential fix.
Claire M.
Technical Support
Certified LabVIEW Developer
(4,389 Views)
As discussed in the LAVA crosspost thread, a well placed Always Copy seems to fix this until there is an official fix.
(4,369 Views)
