Pane Properties Background
Hallo to all,
I'm trying to customize my user interface with a custom image that I used as "Pane Properties" --> Background
Based on your experience, is it possible that with the background the performance is slowed down or the front panel update is slowed down even if the number of controls / indicators has remained the same?
Thank you so much
bye
monica
(2,566 Views)
@scmm wrote:
Hallo to all,
Thank you so much
bye
monica
I expect it's possible, but I'd be surprised if it was problematic.
Is it possible that you're repeatedly setting the same image (because the property node is in a loop, for example) and that this is what's causing the slow-down?
GCentral
(2,560 Views)
