Pan and Zoom in Front Panel and Display Problem by using lot of images
i am using the application which should be displayed in different types of dsiplays such as lap, HD desktop and low resolution windows tab. i am facing the difficulties are application is not fully visible in low reolution tab.. it showed only half of the application.. i am using lot of picture control which i read png images.. which was overlaped one another.. i want the image should be panned and fixed at particular position without breaking of pixels in images..
please help me for come out of this problem..
Thanks in advance
(3,093 Views)
Hi Ragunath,
Have you tried using splitters and then make your controls "fit to frame"? This is what I do for image acquisition or large graphs. That way when the user resizes the application, only the graph size changes. If you want everything to change and look nice across a large range of resolutions, you may have to make separate front panels for each format...
(3,035 Views)
