Palette question
Ok, this is one more of those basic skills that I've never mastered. What is the best way to add the drivers to the instr. lib? After extracting the files from the zip file I've got a set of drivers in .llb and the .mnu files in a directory (see the attached folder view) and I can't get them to show up correctly within the functions palette. All I get is the top level icon for the instrument but all of the subpalettes are icons with question marks.
Help!
(2,717 Views)
Hi denslen,
I was able to download a similar chr6320x driver, run the setup.exe, let the NI Installer use its recommended settings, and view the driver in my functions palette. I didn't actively extract any files or move them around.
Try running the setup.exe that you can download from the NI website, then search your functions palette for chr6320x. Any of the installed VIs will show up there.
Alexandra Valiton
(2,659 Views)
Also, have you seen this Knowledge Base article on installing third party drivers?
http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FD86256F0B0057E6E7
(2,654 Views)
