Paging a pager in LabVIEW
Has anyone paged a pager from labview? I would like code that is working nicely
that I can simply use in my application. I know the serial port VIs can be
used, but I would rather not start at that low level.
Rava
(3,206 Views)
You can send an email from Labview to Ameritech (forget the address)
and it will forward it to a pager...there is a simple SMTP email VI
for Labview floating around. If I come across the email address I
will let you know.... hope that points you in the right direction
>Rava
(3,206 Views)
Volume 5 #1 of the LabVIEW Technical Resource (www.ltrpub.com) has an article
on user pagers as well as a set of vi's.
nicely>that I can simply use in my application. I know the serial port VIs
can be>used, but I would rather not start at that low level.>>Rava
(3,206 Views)
