Packed library in Palette
I have a packed library with several VI and I woul like these Vis to appear in the palette. I copied the packed library into the instr.lib folder. However, the VIs of this packed library do not appear in the palette in  Instrument I/O - Instr. drivers.
How should I proceed to have the these VIs in the palette ?
Fred
(663 Views)
You have to make palette files for things to show up. If you notice in the instr.lib all the "dir.mnu" files. These are what LabVIEW reads to populate the palettes. See the post below on how to do that with PPLs.
https://forums.ni.com/t5/LabVIEW/how-to-add-packed-library-on-palette-set/td-p/1656080
(636 Views)
