Packed libraries in executable
If I am using a packed library and create an executable with an installer the installer puts the packed library into a separate folder in the installation directory.
is there a way to build the packed library into the executable file so it isn’t visible as a separate file
i am nitpicking a little bit but I feel like this is just an extra thing to break on customer installations.
(1,628 Views)
Accepted by topic author Worle
Nope.  What you are asking for is like embedding a DLL into an executable.
If you don't want the PPL there, then use the raw library you built the PPL from.
(1,594 Views)
Thanks, I suspected that might be the case
(1,582 Views)
