Package Manager Error with Web Module
Hi!
    solving the problem with NXG from Beta to 2.0 I deleted manually many files, maybe too much.
At the moment, NXG is working but trying to install web module, Package manager says me:
Unable to locate package: ni-labview-nxg-2.0.0-web-module
It seems that a feed is missing.
I've checked feeds using the gear at the right-top of package manager but it seems there is no feed about web module.
Should it be there a feed about web module?
If you have it, could you give me package name and location to add it manually?
Thank you!
(3,361 Views)
Hi gepponline,
Unfortunately, since I don't know what all you've deleted, I think the best step at this point will be to remove NXG through NI Package Manager and reinstall it. I'd recommend installing components piece by piece if possible to see which component is causing the original crash you were seeing mentioned in the other thread.
If you have standard service with us, I'd recommend opening up a Service Request so we can better assist you with this issue.
Andy F.
Applications Engineering
(3,314 Views)
Already uninstalled and installed several times.
I've already have an open SR but no solution since now.
(3,294 Views)
At the moment I've been able to install the web module, but whenever I try to open a WebVI project, from a new template or from an existing VI it give me error as the attached image.
Then I noticed that quite all the links inside the nipkg.ini file are referred to a beta2 path.
Could it be the problem? that somehow even uninstalling the package manager, the beta version of nipkg is stille there?
I attach even the .ini file to check it.
(3,293 Views)
