PXIe List of Available Signals
Hello everyone,
So I have a PXIe chassis and a bunch of PXIe 4300 AI cards. The test setup is regularly changed which means at any point the chassis could have any number of slots filled with these AI cards.
I want to write a program for acquisition such that the VI recognizes which slots are available and exclude the blank slots.
I realize that in the DAQmx Create Channel task, there is an input where you list the physical channels you want to acquire from, but how do I get the list of all available channels so I can feed it to this physical channel field?
I am relatively new with LabVIEW. Seeking help! Thanks in advance.
(563 Views)
Hi Silverfang,
using the SystemConfiguration API you can determine all available devices…
(539 Views)
Accepted by topic author Silverfang-
Retrieve All DAQmx Physical Channels of a System Programmatically
https://tmesystems.net/
(513 Views)
Thanks. I tried both ways and the SystemConfig API method worked too but I think this is a simpler way to get all the active slots.
(498 Views)
