PXIe-6544 HSDIO Waveform Generator
Hi NI Community,
I'm trying to use the module HSDIO PXIe-6544 to generate a clock (square wave) of specified frequency. I found an example in the LabVIEW examples but it is not doing what I want it to do. Can you please help?
Thank you!
(1,777 Views)
I tried adding 0101010101 pattern and it seems to be generating the clock but how do I make the array infinite so the clock runs forever?
(1,775 Views)
I'm not familiar with niHSDIO so I might be wrong.
You can try using the niHSDIO repeat mode in continuous mode to repeat the array.
(1,733 Views)
Thank you for your response! I will check it out
(1,718 Views)
