PXI Chassis Power LED Flashing Red: What to do?
My NI PXI-1042 keeps blinking red the Power LED. I know it means the voltage is out of the specs. What to do?
(8,589 Views)
Hi.
           Follows a link for your query: http://digital.ni.com/public.nsf/allkb/A15DFD6915FED85386256E680061D55D?OpenDocument
Diogo
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(8,525 Views)
But it is not continuously red.. It is blinking red.. Thanks for your help. Anyone?
(8,521 Views)
This is copied right out of the manual:
The chassis power switch has an integrated LED. This LED indicates one
of three different conditions:
• If the power switch LED is steady green (not flashing), the chassis is
powered on and operating normally.
• If the power switch LED is flashing green, the air-intake temperature
has exceeded the chassis operating range.
• If the power switch LED is flashing red, the power supply outputs are
not within voltage regulation requirements.
You either have a power supply problem, or you are loading it down with too many modules.  Try running it empty and see what the light does.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(8,501 Views)
