PXI 7813R Serial Number query
I Folk,
I am working with a PXI-8106 (Windows, LabView 8.5.1) and one card PXI 7813R, how can I query with LabVieW the Serial Number of the PXI 7813R card?
When I expand "Devices and Interfaces" in MAX and select my "RIO device: RIO0" the Serial Number and the Model Name are displayed. How can I programmatically get this information?
By searching in the forum messages, I have found examples that display Serial Number of different PXI cards by using DAQmx properties and VISA queries, unfortunately both approaches seem not correct with the PXI 7813R.
How can I solve this problem?
Asper
Message 1 of 10
(4,103 Views)
Hi Asper,
I would use the
DAQmx property nodes. They've always worked for me using cDAQ and cRIO, and they would work with PXI - though I havnt tried it.
Maybe have a look at link -
contains an vi to do it.
Could you maybe send me your code?
Have a good day.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 2 of 10
(4,085 Views)
Hi Hillman,
I believe that the PXI 7813R is not a DAQmx device.
I have attached the VI to read both DAQmx and VISA information and the scree shot of the front panel after run on my PXI, furthermore I have attached the screen shots of the MAX details of both PXI Chassis and RIO0.
Any further suggestion?
Asper
Message 3 of 10
(4,075 Views)
The VI to read both DAQmx and VISA information.
Asper
Message 4 of 10
(4,073 Views)
Hi Asper,
I am very sorry, I should have noticed it wasnt a DAQmx device.
I think your on to something with the VISA nodes.. this is what MAX uses.
I have a knowledge base article with a vi which on the face of it should work. Take a look,
link, at let me know if it works - if not, I'll look into it further.
Thanks again,
Kind Regards
James Hillman
Message 5 of 10
(4,054 Views)
Hi Asper,
The VISA property "Interface Information > Interface Description" contains the serial number. You just have to parse the string to extract it.
Hope this helps,
Daniel
Message 6 of 10
(4,045 Views)
Hi
Thats excatly what the link says.
Glad thats sorted.
Have a good day.
Kind Regards
James Hillman
Message 7 of 10
(4,040 Views)
Hi Asper,
I think the following links are what  your looking for as they address your exact question:
How Do I Programatically Get Backplane Information of My RIO Device?
CompactRIO Information (CRI) Com...
Hope that helps,
Basset Hound
Message 8 of 10
(4,021 Views)
I also found it difficult to get the Serial Number from RIO devices.  I found sample code @ How Do I Programatically Get Backplane Information of My RIO Device? that solved my problem.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 9 of 10
(3,999 Views)
Hi Hillman and Daniel,
thanks, this is exactly what I was looking for.
Asper
Message 10 of 10
(3,936 Views)
