PXI-6071E daq programming
Dear all,
        I am using PXI chassis  PXI-1002
 controller PXI8176 and
Multifuction DAQ PXI-6071E
I want make continuous data acquisition for this, how i can go?
--Vishnu
(2,657 Views)
Vishnu,
you can first tell us which programming language you are going to use. Since you are posting in the LabVIEW forum, i assume that this will be LV.
So please take a look into the example finder (Help >> Find Examples) and look for DAQmx (the driver used for the DAQ device).
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,647 Views)
Dear Norbert B,
         Thanks. I am using Labview7.0. I will try as per your guidance and come to you again.
--Vishnu
(2,624 Views)
