PXI-5152 noise filter enable and verification
How do I enable the 20MHz noise filter on the PXI-5152 using NI-SCOPE in Labview?  Is there a way to confirm the noise filter is enabled?  I do not see an obvious property to read the setting.  I tried setting the "maximum input frequency" to 0 for enabling the hardware default but it is not defined.
Please respond as soon as possible.  Thanks!
Message 1 of 1
(456 Views)
