PXI 4461
I have a problem here with RT Controller and PXI-4461 DSA.
I am using PXI 18 slot chassis with LabVIEW RT 7.0. In all the 18 slots i am using 10 slots,recentely i included PXI-4461 DSA module. The problem is i am not able to see this device from NI-MAX. I contacted NI,India for the support and as they suggested to upgrade my NI-DAQ 7.0 to NI-DAQ 7.4. Even after upgrading my NI-DAQ to 7.4 i am able to see this device from MAX whereas i am able to see all other devices present in my PXI-Chassis.
I am not able locate what exactly the problem is....??
Request you to kindly help me out.
-Anil
Anil-B'lore
(2,882 Views)
Hello Anil,
The PXI 4461 is supported in LabVIEW Real-Time 7.1 with DAQmx.  DAQmx support is not available with prior versions of RT, so you will not be able to use this device until you can upgrade to LabVIEW Real-Time 7.1.
For more information about driver and device support in LabVIEW Real-Time, please visit the following link:
http://www.ni.com/support/labview/real-time/drivers.htm
I hope this helps.
Kristi H
(2,866 Views)
