PXI-4110 question
Hallo
I have a question about the DC Power supply (PXI-4110) , is there anyway to use it from -V to +V  (e.g. -4V....+4V)
if yes how ?
Thank you in advance
Toni
(2,725 Views)
There are three channels, ch0, ch1, and ch2.  The second channel, ch1, is capable of outputting up to +20v and the third channel, ch2, is capable of outputting down to -20v.  So you can use the last two channels, channel 1 and 2, for +/-4v.  When you program ch 2, you must put in -4 as the value.  You cannot put in a positive value.  However, when wiring, the Lo (-) terminal of ch1 must be wired to the Hi (+) terminal of ch2, and this is your ground reference.  The Hi terminal of ch1 will be +4v and the Lo terminal of ch2 will be -4v.
- tbob
Inventor of the WORM Global
(2,715 Views)
