PWM signal generation
I want to generate a 10 kHz square wave with a 500 kHz modulation signal. I used a AND gate to combine these two signals. But the output only has the fundamental 10kHz signal no 500kHz modulation signal within it. I have measured the output of 500 kHz and 10kHz signal generator separately. Both of them have correct output. But once I use an AND gate to combine them. I can only get the 10kHz fundamental signal at the output. Can someone please help??
(3,845 Views)
can someone please help? Really appreciated
(3,839 Views)
Hi 8D,
          For PWM signal generation.
Here you can find an example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E9F156A4E034080020E74861&p_...
You can get some more info from the following link: http://sine.ni.com/devzone/cda/epd/p/id/651
Thanks as kudos only:)
(3,835 Views)
Hi Danil,
your two links both show the same outdated example...
Did you notice the OP is using the FPGA of it's RT target?
@8D:
- Your pic doesn't show any timings...
- Which hardware are you using?
- Is the DIO capable of outputting at 500kHz?
- Bumping a thread after just 2 hours on an early Monday morning is quite annoying...
(3,818 Views)
Hi
Thank you both for advices. Problem solved. I put the two PWM generators in 2 separate loops and then use AND gate to combine them. The resultant waveform achieves what I want,i.e. fundamental comprising the modulation signal.
(3,780 Views)
