Hi again!
You're probably right about directly writing to the registers being faster, since Visa is a high level(and hence, probably, slower) environment. If you're comfortable with all that peeking and poking, I'd go for it. There is a good tutorial on general Parallel port stuff on the main NI site. Indeed, win2000 is NOT the preferred platform for this sort of thing....I've had better results with win98, but alas..."progress" marches on.
I don't know why you're having a timeout problem with the PWM circuit. (I've also missed some of the discussios for some reason. I'll check into that)
By the way...I work for HIPAS Observatory here in Fairbanks, Alaska...we're under the UCLA plasma physics department...we do io
nospheric research...poking the Aurora with lots of High power RF...that kind of stuff. Our web site (if it's working) is www.hipas.alaska.edu. We're moving toward converting ALL our remote data acquisition to Labview. (other than a few diehard Matlab grad students...he he
🙂Chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
