PWM code Errors
I have 8 servos, controlled by sbRIO FPGA. Problem is if I insert a certain value in the control of any servo, it affects the movement of other servos.
Example: I set value 2200us at servo 8,  1000us at servo 7,  1000us at servo 6,  1000us at servo 5,  1000us at servo 4,  and so on. As I gradually change the values, somehow my Servo 8 moved eventhough it is still set at 2200. I can't really seem to figure out why so I think maybe it is the wrong coding method in FPGA. Need some input from you all, thanks
(2,810 Views)
Hi august,
you already had a lot of input from us all! Why didn't you continue your old thread?
(2,806 Views)
This is not regarding any delay, just the concept of getting servo control via FPGA. I'm not sure whether the above arrangement are correct or not.
(2,799 Views)
