PWM Signal Generation Using Counter input
All of you,
             I need to generate a PWM signal using the counter output on the PCIe 6343 device. I also need your assistance to measure the frequency, duty cycle, and voltage in the analogue input.
(1,743 Views)
Accepted by topic author karuppananK
Hi karu,
So what have you tried?
Where are you stuck?
Have you studied any of those DAQmx example VIs coming with LabVIEW+DAQmx? They explain how to output PWM signals and how to measure voltage signals…
Do you really want to measure duty cycle on a voltage input? Will a (TTL-compatible) counter input aso do that job?
(1,740 Views)
