PR 4000 basic serial write and read.vi
Hi
All
I have got a lot of help from the forum
The PR4000 driver works . It can read the data. But I try to use  basic serial write and read.vi to test MKS PR4000 read out.
No response showed up....
(3,047 Views)
I am also confused with "flow control" IN THE FRONT PANEL . How should I set up it?
(3,045 Views)
Hi All,
Can you be more specific on where you get confused?
Thanks and have a great day.
(3,012 Views)
Check all of your settings.  Baud rate, stop bits, parity, flow control (set to none unless you have problem with buffer overrun).  You probably have a setting that doesn't match, or you cable is not the right kind.  Is the end device considered a computer device or terminal device.  It should be terminal.  If not, you need a null modem cable.
- tbob
Inventor of the WORM Global
(3,007 Views)
