PMD-1208LS
Hi everybody,
LabView is new to me, and I've 12-bit channel USB-interface how does a
USB work with LabView 7.0 express?. The drivers are install but when I
choose a board number an error is displayed "invalid board number".
Thank you very much,
Scopas.
(5,631 Views)
Is this a Measurement Computing device? If so, have you installed their Labview drivers? I have a USB PMD-1024LS and I am able to use it with Labview 7. After installing the MCC Universal Library and Labview Library, configure the board number using their Instacal tool. Your board should show up on the front panel list of devices. Right click on your device and select Change Board #. Then use standard Labview DAQ vi's with the new board number. At first, I mistook the board's configurable serial number for the device number. They are two different items.
- tbob
Inventor of the WORM Global
(5,632 Views)
Hi Tbob
reading Adept scientific forum:
http://www.adeptscience.co.uk/kb/article/D7A2
with regard to MCC compatible lvdaq.dll file. Does this mean that if I attempt to use  another application built with NI lvdaq.dll that it will function as per expected or crash due to incompatible  DLL configuration ?
I have a USB PMD-1208LS  that  I am at present unable to load univeral labview driver as installer cannnot see labview 7 , so does not complete execution.
At present two options : try to resolve conflict or purchase NI low cost USB DAQ.
Personally I'm looking at NI solution as I was not involved with start of project with OEM  equipment.
Chow
xseadog
(5,443 Views)
