)PLS( UAD2+ control using I/O Assistance
Dear,
I'm tring to control a Univesal Access Device from PLS to program STR7 microcontroller using I/O Assistance.
this device can be accessed by two ways:
  1. USB2
  2. Ethernet.
Can I use I/O Assistance to control this device through USB2? If yes, How from A-Z?
Can I use I/O Assistance to control this device through Ethernet? If yes, How to configure the nertwork to be listed in the I/O Assistance instrument list?
(3,157 Views)
Here are a few resources that will help you control your device. These resources explain all the steps. First link is to learn more about I/O Assistant and get used to using it. Second link will help you control ethernet devices using VISA. You have to understand that I/O assistant generates a VISA code.
https://www.ni.com/en/support/documentation/supplemental/12/instrument-i-o-assistant-explained.html
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
Arjun K
(3,133 Views)
Hey where dd u buy this PLS UAD2+... I want complete buying procesure???
(2,778 Views)
Hi 47645ist,
I'm not sure if the member who originally posted is around to comment, but I would recommend that you contact PLS about purchasing the part. A quick google search on the product returned the following useful site:
Communication Hardware "Universal Access Device 2+" - UAD2+.
Sanjay C.
Embedded Software Product Manager| National Instruments
(2,755 Views)
