PID timeout myDAQ
We using a myDAQ to view PID readings with a provided LabVIEW VI from national instruments.
We have connected a motor to a voltage source and a hall effect sensor than we are feeding into an analog input port on the myDAQ.
We have verified that the hall effect sensor is working properly, however, every time we run the VI we get a timeout error.  We have tried every port on the myDAQ and every other team is experiencing the same problem.  Our motor is not able to spin very fast so we believe that might be the cause of the error.
I will post some screenshots later of all the timeout errors we have gotten.
What could be the possible causes of this timeout error?
(2,562 Views)
Post a snippet or the vi that you have made then its easy to see why the timeout occurs.
(2,555 Views)
