PID speed control
@AndyClegg wrote:
The sample time should be at very most 0.2x the time constant (*) of the response you want get, but as a guideline I would always aim for 0.04x just so that it can be negligible. (*) - note time constant here is for first order response, so for a more general system rise time = 4 x time constant.
Dear Andy,
I am very interested in your statement here which might be the solution of a problem I am facing now.  I hope you can give me some advising.
The sample time should be at very most 0.2x the time constant (*) of the response you want get.
I wonder where do you get this coefficient of 0.2? Is it based on your past experiences or theoretical derivation?
May I know how do you obtain this coefficient of 4?
Based on what you said, rise time is 100x sample rate, may I interpret it as the controller needs to iterate 100 times to make the output reach the desired value?
Looking forward to your reply.
Best Regards,
Jake
Message 21 of 24
(1,368 Views)
If you sample too slowly it can degrade the closed loop perfomance from the nominal continuous time response - the sampling introduces extra phase shift that can destabilise a control loop. The sample time being at least 5 x faster than system time constant to ensure the sampling doesn't degrade performance significantly. This is more a guideline though I am sure you coud define an exact figure based on a continuous to discrete transformation (s to z).
As noted I woud always try to make sample time x25 faster if you want to ensure the effect of the sample time is negligble.
For a first order system it can be regarded as being in steady state after 4 time constants (it will be about 96% of way there, so not exact). Rise time is usualy defined as time it takes to get from 10-90%, so that could also be about 4 time constants - again not exact but close enough for most tuning requirements.
Consultant Control Engineer
www-isc-ltd.com
Message 22 of 24
(1,368 Views)
hi can you show, diagram block from labview pls
Message 23 of 24
(685 Views)
@Silver_Shaper wrote:
Dear Andy and Gerd,
Sorry for keeping this post open for the long duration.
I have finally done with my PID Speed control and please find the result in the image (sorry for bad quality - its captured in mobile). I am happy with the rise time, overshoot, undershoot, step response (not shown here), ramp response and oscillation/quantization errors.
Thanks for all your help and suggestions. I am closing this post. KudosSmiley HappySmiley Happy
It's good Forum etiquette to engage with the community to communicate the actual solution since we were willing to engage with the problem. It's a give and take. Others may well profit from the actual solution you found, turning your post into a source of information rather than a request for help.
Please post a description of HOW you solved the problem so that others can share in the outcome.
Message 24 of 24
(659 Views)
