PID position control : guide me
Dear member
I want to built a PID position control
i read the DC position through potentiometer with -128 to 127 [full 360 degree]
so the input to the pid is voltage range between -128 to 127
the input of dc motor is PWM and the motor rotate direction
so the PID output will be PWM
what about direction bit ??? What will be it circuit
also how to control the speed in same system ?? is thire another PID??
best regards
hi ?Q>
(3,205 Views)
Hi mangood,
you can have your PID to output a value from -100 to +100 (like % as unit). Then use the sign as direction bit and the value as speed…
(3,199 Views)
@GerdW wrote:
Hi mangood,
thank you
what about control the position and the speed at same time ???
hi ?Q>
(3,193 Views)
Accepted by topic author mangood
That's a complicated problem. A quick internet search turned up this paper which describes some possible approaches:
http://www.idt.mdh.se/kurser/ct3340/ht09/ADMINISTRATION/IRCSE09-submissions/ircse09_submission_22.pd...
(3,174 Views)
okkkkkk
terrific paper
hi ?Q>
(3,149 Views)
