PID output range
Hello guys
I have a question concerning the PID VI and it's output range option.
how to set PID output range for the sistem that process variabel and set point are in LPM (flowrate), and the acuator is servo that the output are in degress?
help me for myquetion
Thank you
-chris
(1,782 Views)
Accepted by topic author Cristophergahar
Hello, Chris.
     This is your second Post on the LabVIEW Forums, and you haven't learned the lesson from your earlier post.
Please do the following:
  1. Tell us what version of LabVIEW you are using (for example, LabVIEW 2019, SP1, 32-bit).
  2. Tell us what version of the LabVIEW myRIO Software Toolkit you are using.
  3. Your header tells us you are using a myRIO, a Servo Motor (not specified), and a Flow meter.
So far, you haven't explained (clearly) the Task, you haven't told us what you are trying to do, and you (again) have provided no code.
Please describe more clearly the Task.  Also, in your Reply,
  1. Right-click the folder containing your LabVIEW Real-Time Project, click "Send to", and choose "Compressed (zipped) folder".
  2. Attach the .zip file to your Reply.
     Do not attach "pictures of code".  Do not send a .rar file.
(1,746 Views)
