PID-Control (Tank Level)
Hi!
I want to realize a PID-control for a tank level. I've already looked at all related examples in LabVIEW, but I have a general question:
Where is the measured value brought into the process (where would I connect the DAQ to the control-loop)?? I can't figure out how it's done in the examples (there is always an "initial value" outside the while-loop)....
Would be great to get some answers!
(3,764 Views)
Generally you take the DAQ value and feed it into the PID as the process variable.  The examples store the process variable in a shift register in order to simulate a system in which the current value depends on the previous value, but in a real system the physics of the system handle that for you.  For example in a tank control system, the tank itself holds some amount of liquid, which doesn't change by a large amount within one sample period.  To simulate that properly you need to store a value equivalent to the liquid volume in a shift register.
(3,744 Views)
