PIC
Saludos a todos tengo un problema, no puedo enviar ni resivir datos estoy usando windows 8.1 y LabVIEW2014 para realizar el control de un motoreductor de cd usando una tarjeta PIC-SERV SCv1 y para la comunicacion USB con LabVIEW la tarjeta SSA-485v2, ambas de JrKerr en su sitio web encontre la libreria para labVIEW, corri la funcion PIC-SERVO TEST pero inmediatamente al correr el programa me aparece un error es el siguiente:
Tengo conectado el USB y lo detecta como COM3 revise las demas conecciones en el hardware y estan funcionando revise el Measurement & Automation Explorer y me arroja error para LPT1 ver
para mas detalle encontre: Error.png
instale el driver par la tarjeta SSA-485 pero no encuentro cual es la falla. Alguien tiene alguna referencia o idea de como soluconar este error o algun consejo se los agradesco
Message 1 of 9
(6,102 Views)
You should be ignoring the parallel port in MAX. It's not at all relevant since you are using a com port.
Could you give the link to this driver? On the image of the front panel, I don't see where you specify the port.
Message 2 of 9
(6,016 Views)
this is the link of driver to SSA-485: http://www.ftdichip.com/Drivers/D2XX.htm
Add data sheet for this board
http://www.jrkerr.com/boards.html
http://www.jrkerr.com/software.html
 only in this part I set de Baud Rate?
immediately appears the message
Message 3 of 9
(5,901 Views)
I don't know why you pointed to the D2XX driver since that does not create a virtual com port. Good you really install that or did you install the vcp driver?
Message 4 of 9
(5,890 Views)
yes I installed the vcp driver 2.12.00 WHQL
Message 5 of 9
(5,732 Views)
Since you apparently got that utility program from the vendor, I would suggest contacting them.
Message 6 of 9
(5,690 Views)
Ihave a question:  it is normal that appears the parallel port ASRL 10INSTR"LPT1", even without connecting any interface USB to PC
Message 7 of 9
(5,652 Views)
Perfectly normal and its perfectly normal that it appears with a red x. As mentioned earlier, you just ignore it.
Message 8 of 9
(5,643 Views)
Que tal FFRR
Como te está apareciendo un error de Timeout en la comunicación serial yo trataría de ir por partes. Primero tratar de comunicar via un programa de Hyperterminal solo enviar y recibir comandos seriales de la tarjeta que tienes. Asegurate que del Datasheet tengas todos los parámetros para la comunicación serial de manera adecuada.
En segundo lugar al asegurarnos que ya haya comunicación serial sería revisarlo desde LabVIEW, debe de haber alguna otra ventana de configuración para las propiedades de la comunicación serial. Checar que todas estas estén bien configuradas. Si tienes el código fuente de este VI revisaría en que momento se está generando el Error de Timeout, que es lo que está haciendo ese VI para revisar si en ese momento estámos perdiendo comunicación con la tarjeta por alguna otra causa.
Cualquier otra pregunta quedo a la orden
Saludos
Juan Arguello Director Support Services @NI
Message 9 of 9
(5,622 Views)
