PDA module - PDA questions
1. How to run the PDA excucutable from PC? I can not debug the PDA
application from PC. I try to run the application from PC but got
dialog box pop out and show "connection status progress..." and then
the dialog go away. Progress bar never "progress".
2. I copy the PDA excucutable to the PDA by ActiveSync. How can I
enable the Cursor legend and Scale legend for the
PDAwaverFormGrapg_2x.ctl? After I run it,I can not see the
cursor/scale legend. It only show 1 cursor (I need two)the drop down
box and X/Y value. So how to scale? How to set sursor pattern?...
(4,061 Views)
You'll want to use the Emulator. It lets you debug them before you try to send them to the PDA. This KnowledgeBase will starting leading you through the steps of doing this. Hope this helps get you started.
J.R. Allen
(4,061 Views)
