PDA build error when using a 'value change' event on two controls
I get a build error when I use a 'value change' event on controls of a different type or even a different numeric representation. I'm using LV 7.1 PDA with no other modules installed. Attached is a picture of the entire code and the error message.
___________________
Try to take over the world!
(2,444 Views)
I verified the error that you are seeing. It appears to be a bug hence I have reported it to our developers. Hopefully this bug would be fixed in the next relaese of the PDA module.
Thank you for pointing this to us. It is through feedback that we can make LabVIEW PDA module even better.
Ankita A.
(2,428 Views)
